Thread: Which Carb?
Old 05-26-2004, 10:46 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Knew I had seen that plate on I75 I think. Near Troy?
Why are you changing carbs?
The Holley should provide good coverage of the RPM spectrum. However, if you are running higher RPMs than the carb can flow, you might be getting a flat topend.
Do you ever make it up to the FLint area?
Just my $0.02 with a couple of questions.
