Old 05-27-2004, 03:42 AM
RACER X #99's Avatar
RACER X #99 RACER X #99 is offline
Default Your OK
The Green rule seems to overide all the other rules. If you show enough green(entry fee) you can run.
To be serious for a second, the tracks have backed off a little on the requirements for full rollbars in Cobras. As long as you have a drivers side rollbar you can run. The only problem is that some instructors will not ride in a car with a single hoop rollbar.In that case you have to do lead follow instruction which takes much longer to learn the line and track etiquette.
Sign up, we will work with you.
RD
