Old 05-27-2004, 06:59 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
I had a bit of a measure up and a ponder in the shed tonight and I think it'll work a treat. The high pressure fuel pump assembly will fit nicely inside a 4" diameter tube by about 10" long so it'll make a nice swirl pot. There's plenty of room on the rear inner guard to mount it, the low pressure lift pump and 2 filters.
There will be a single high pressure line from the running from the pump/swirlpot to the engine bay since the regulator will be in the swirl pot. There will also be a vacume line to the motor for the carbon canister. I'll mount the carbon canster on the other side inner guard next to the filler neck. Should make for a clean un cluttered engine bay.
Mike
Mike Murphy
Melbourne Australia
