Old 05-27-2004, 08:30 PM
NASSTY NASSTY is offline
Cobra Make, Engine: RCM, 4 wheels, two doors
Shelby400
I know a lexus v8 will fit into a RCM. I have seen a RCM roller with one installed. It does require mods to the footwells to fit but it's nowhere near as much as say a Boss 5.4 This roller also used the steering column too, for ease of wiring I think.
Did you use a lexus column and ignition?
From what you've said, modifying the wiring loom appears to be an easy fix.
By security I mean some ECU's require the ignition key/ECU to be matched together or the ECU won't fire up. When you had your loom modified I assume this problem was fixed?
As for ADR 79/00, 79/01, I had also heard (but not by an engineer mind you) that the motor would pass. Need to find out more about this!
Thanks
