Old 05-29-2004, 01:16 PM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Dane,
From the looks of the picture it looks as if your fitting could be glued back. I once glued a vacuum fitting almost like that using E-6000 and it never did give me any trouble. I got rid of ther car about 3 years later and it was still great. Only thing is the E-6000 takes about 24 hours to really set up and you have to be careful to not get any over the end of the fitting. I just took a littleon my finger and put it around the edge of my fitting and waited a minute or so until it was sort of tacky then pressed the fitting in tight and wiped away a tiny bit that squeezed out the top. Then I used a rubber band to hold it tight overnight and it was ok. There are other types of epoxies that would probably work better now as they set up faster.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
