Thread: Insurance
Old 05-30-2004, 06:55 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I had the long input shaft and big bellhousing for the T-5, I have changed to the shorter input shaft, bearing retainer and bellhousing, I am using the CNC slave cylinder, my clutch releases about half an inch from the floor, if I go futher, then the clutch slips, I am running the King Cobra clutch and pressure plate 10.5 inch, I built the mounting bracket for the slave cylinder per instructions, there just isn't enough movement on the clutch arm. The cylinder I have found is a MICO slave cylinder, I don't want to buy it, if it won't work either, I don't know if I will get enough movement with my 1" wilwood master cylinder. The spec sheet says it takes .61in3 to get full stroke, I don't know how to figure how much fuild the master cylinder will push.
PS I am working nights, sorry about the late posts.
PapaJohn
