Old 06-01-2004, 04:37 AM
Teriable Ted13 Ted do you have a SFI bellhousing on your motor? Blow proof? I would go with an 11" clutch due to the hp and tork you are make. I have an Ram flywheel, 15 lbs with a gold centerforce clutch assembly. I removed the wieghts for a shifting problem and have had no problems since. The orginial flywheel was 40 lbs. What a different with the car. Match the clutch to your driving needs. I autocross,roadrace and 1/4 mile. 1/4 mile is the toughest on the clutch. Unless you are racing all the time any clutch will be fine.Check for SFI sticker for safety. 2800lb pressure plate and disc should be great. High pressure numbers unless it is a twin disc will be harder on your clutch master or slave cylinder. Good luck Rick Lake
