  #33 (permalink)
Old 06-01-2004, 11:03 AM
rritchey rritchey is offline
Cobra Make, Engine: None yet, saving $ for a Kirkham. Buy a FE from me and I'll be that much closer.
Default you guys are a bunch of naysayers.....
I have attached a scan of one of my dyno sheets...
The motor is a '63 427 center oiler with 428 crank, .017" over, JE pistons 10:1 compression, Edelbrock heads mildly ported with CJ sized valves, mild solid flat tappet cam. It has lemans rods. Edelbroc Victor intake, Demon 950 CFM carb (too big, but that's what the customer wanted...). This is not an all-out race engine by any stretch... pretty basic build.
Max power was 553.9, max torque was 567.1. The numbers indicate the small size of the cam, as HP was lower than torque.
The scan is pretty dim, but if you view it in windows imaging you can zoom in on it and it is readable.
My shop is in Arkansas, but I use a dyno in Tulsa (also a Superflow)... maybe it's just the air here
Randy Ritchey
Thanks for looking and have a blessed day!
"For whosoever shall call upon the name of the LORD shall be saved."
Romans 10:13
