Old 06-02-2004, 04:03 PM
Buzzmobile's Avatar
Buzzmobile Buzzmobile is offline
Cobra Make, Engine: SPF 148 with 427 SO
I bought mine used and the track/rails had bound up on mismatched teeth and locked. Just popped out the seat with a 1/2" deep socket and manually realigned the teeth after a good bit of lube. After working the rails back and forth while the seat was out and after the lithium grease, they really loosened up. Just one thing I found out going back in. Don't put the seat all the way forward or all the way back on the rails as it binds when you tighten the bolts down. I found that 10 teeth from the back put the seat right in the middle of the "usable" travel for adjustment and the seat went right in.
