Old 06-02-2004, 11:04 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Default Sealing Windshield rubber to body
My windshield was prone to leak all along the bottom between the rubber gasket and the body. I used a 3M adhesive glass seal tape to "glue" the rubber to the body--this tape is used to seal glass panels in construction so the glass doesn't rattle against the frame, very strong, super thin tape, adheres to most any surface.
I cleaned the area under the gasket and the gasket with de-natured alcohol--I did pull the windshield first--applied the tape to the body, reinstalled the windshield, then "sealed" down the gasket to the body.
Only 2 small less than 1'' openings now at each windshield frame post where I didn't run the tape. Now I don't have water seeping in all along the windshield bottom like before.
FWIW
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
