Old 06-03-2004, 07:18 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Wilf....
Believe it or not they did not glow, but then again it was broad daylight therefore, prehaps in the evening under soft lights, we might enjoy afore mentioned glow
OH, and she WAS running in those pics! Just 2250 RPMs however.. I would not wanted to be in there under full RPMs!
Lowell, believe it or not this motor fits under the stock hood. This was the reason for replacing the Victor Jr. intake in the beginning: It would have required a large "Pass thru" hood scoop which I did not want. I will admit that with the Demon carb I had to use the tiny triangular-shaped Edelbrock foam filter setup. With the impending EFI/air door I can use the oval Cobra system with my K & N filter, without hood mods.
Less than 2 weeks now to sit behind the wheel and hear that thunder again.. suffering from cobra withdrawl
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
