Old 06-03-2004, 01:26 PM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Mustang II Front End Coil Overs
Okay, I do not mean to sound Dumb, but I am a little confused. I have the Mustang II front end on my kit and it has coil springs around the stock shocks. So, my question, which I did a search on and could not find the answer to, is when you go to Coil Over Shocks do the new coil overs fit inside the exsisting coil spring, or do the coil overs replace the exsisting shock and exsisting spring?????? I'm so cornfused....somebody please help me get uncornfused before I go nuts......oppps, to late my wife says I'm already nuts. Also, on the rear end, when you use Coil Overs, since the shock is not inside the spring as on the front, do you leave the stock spring or remove it?? Toooooooo many options!!
HELPPPPPPPPPPPPPPPPPPPPPPPPP?
Safe Flyin, errrrr Drivin, Earl
