Old 06-03-2004, 01:48 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
Talked to Regg, the switch is a generic switch - not BMW. He is getting a part number and a source for me.
As for the mechanical switch, I was going to mount a doorbell button behind the pedal, but Jim's refridgerator switch is better. It is better to have the switch release to turn on the light rather than depress. Depressing the switch requires a switch that will contact immediately but still be able to travel with more depression of the pedal. Jim's switch is opposite so extended pedal travel is no problem. I did mount a temp switch made from spring steel and a wire contact that works well because the spring steel will move with the pedal.
tfarhood
