Old 06-03-2004, 06:13 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Especially because you live in NJ, you would be well advised to only consider purchasing a block with a PRE-1974 serial number. Since NJ requires your engine to have ALL emission devices present and operational for the year of your engine, pre-1974 is the way to go. I'm certain you don't want to have to fiddle with EGR valves and air pumps, etc. I personally chose a 1969 351W engine from a salvage yard and completely rebuilt it. You might try the Engine Factory in Lebanon, NJ (http://www.enginefactory.com/). They have a good reputation for quality. Another good source is Jasper Engines. Either of these suppliers should be able to supply you with a pre-1974 serial number long block. You'll be glad you did in NJ.
http://mywebpages.comcast.net/superhart/vcadapter.htm">SuperHart's VALVE COVER ADAPTER & DUAL QUAD INTAKE PAGE
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
