Old 06-03-2004, 09:31 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Boudy
Thanks for the help, after slapping the tank with my hand the last time, it immediately went to empty and stayed there so it may be a loose connection at the tank. Haven't had the chance to take the car out recently to see if a few bumps will change things around, but when you get the info for testing everything, I'll be waiting.
Just curious if you've ever dropped a tank? Doesn't look too bad, a couple of angle iron braces need to be removed and disconnect the fuel line and fill line. Hardest part is draining the gas since I don't have access to a lift.
Thanks again
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
