Thread: Turn Signal
Old 06-04-2004, 09:48 AM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
As a thought have you tried a new flasher? I experienced the same thing with my wife's old Cherokee, lost the ts on one side, replaced the flasher with a new one from NAPa and still didn't work, finally I pulled the flasher from my PU, put it in and ts worked--the new flasher was bad out of the box.
Another thing if you have a hazard flasher do the lights flash with it? If not it maybe likely due to a loose or poor ground on that light circuit. If it does I'd suspect the ts flasher.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
