Old 06-04-2004, 11:23 PM
Rick Parker's Avatar
There a couple of ways to do this. Ford has available black rubber caps that will fit over the heater hose outlet that you are not using, they are secured with a hose clamp or you can drill and tap the housing for an internal hex tapered pipe plug. Regarding the bypass hose, most people use it. It equalizes pressure buildup before the thermostat opens. If you elect to run without thermostat (not a good idea) you can delete the bypass hose and related connections.
Rick
Rick
