Old 06-05-2004, 08:08 AM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
I have basically the same engine as you, but it fit great between my lonestar frame rails. My problem was with the shifter on my toploader. I had to notch out a 3" section of the corner of the seat pan. After that, I welded 1/4" steel to fill in the hole I had cut out. No problem. I also had to cut the side of the bellhousing by the starter.
Good luck, Tim
" It ain't no big deal"
