Old 06-05-2004, 03:04 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Dane I think it is called a circuit toner, I looked at mine all it says is Radio Shack, no numbers or anything. It is a 2 piece tool, one end has a alligator clip you attach to an exposed wire or a pin probe you can push into a connected wire sheath this piece then emits a "tone", the "reader" picks up the tone and you can follow the wire to it's source, works ok but not more than 6'' away from the wire though--difference in quality between the RS version and the pro version. The sending unit uses two AA batteries and the reader uses a 9v.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
