Old 06-05-2004, 08:02 PM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Default Wiring batteries in parallel vs. serial?
Ok, I've got two 12 volt 475 CCA batteries. Looking at the wiring, it's set up to be serialized. Do I lose anything by wiring them that way, or is it best to run them parallel and why?
If I need to run the latter set up, how do you suggest to wire? Thanks for the help.
