Old 06-07-2004, 05:16 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Just a thought here, are you sure your oil lines are run correctly? What is your oil temp?
I fought these demons once and if you will barely loosen your temp gauge on your intake manifold and allow the air to burp out while your car is running this will almost asuredly purge all the air out of your system. Naturally, once water starts to ooze out of your temp gauge fitting tighten everything back up.
Good luck.
Clois
"Let's roll"
"Be part of Something Good
