Old 06-09-2004, 06:36 AM
Roy Landers Roy Landers is offline
Cobra Make, Engine: SPF710 514 Stroker
Default Torque to ground
What is the weak point in the driveline in the SPF cars. Present set up is TKO II and centerforce clutch, 8.8 rearend. The 514 stroker is rated at 600 HP, Torque?. Will 15 inch slick damage any of the driveline components with improved traction. TKO II is rated for 475 ft pounds.
