Old 06-09-2004, 11:19 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Arrow Line
Hi,
I've found that the fuel line from the tank to the fuel pump will collapse and starve the fuel pump causing the needle to bounce from 0 to 7 psi. The way to cure it is to put in a metal line ,you can use short rubber lines to secure it as they aren't long enough to colapse with a high output pump sucking on it.
Good Luck,
Perry.
