Old 06-09-2004, 02:17 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I've got steel lines except for about a 2 foot piece between the fuel tank and the start of the steel line as well as steel braided between the mechanical fuel pump and the carb. I'm pretty sure the problem is gauge related because even though the gauge reads 0 psi much of the time, the car runs great and never has a stumble or miss that you'd expect if a fuel line was collapsing somewhere. I'll either switch to an air filled gauge or remove the gauge entirely and just not worry about it since I'm not having any performance problems.
Chris
