Old 06-09-2004, 07:29 PM
Cracker Cracker is offline
snakebit - First of all no one is looking for 100 more HP out of this engine with the limitations set forth. Kieth initially said it should be making 75-100 hp more than what I have so I choose the lesser of the two and he agreed.
Whats the point? I let him ultimately set the parameters of performance increases. Go back and read the initial post and you'll see where I wrote, "should this engine improve dramatically within the above guidelines I WILL become a CHEERLEADER of his technology and services. " clearly defines my expectation NOT to be 800 HP. Anyone else who would expect that would be a MORON! Obviously your just using a wild example to prove a point but the reality is a true non stroked or enlarged 428 ci engine that makes 600+ on pump gas within the requirements impresses me! It often takes alot more cubes to pull that off. Should the poll reflect 600 hp instead of 625 listed? Probably. However, I was once again basing it off what Keith said.
It has nearly 550 hp now - minor changes 600 very possible - 625 hp means I'm a cheerleader! We'll see.
