Old 06-13-2004, 07:43 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
JLW, The rears mount to the same place as the old shocks, you need to use the spacers that we sent with and the new bolts. The fronts will mount just fine with the stock lower arms. You will need to remove the old spring by dropping the spindle from the upper control arm. It makes it easier to loosen the strut rod at the frame so you can drop the lower arm with the spindle as low as you can. If you have a front sway bar you will need to remove the bolt where it attaches at the lower arm. You will need to do a little fitting with the spacers on the bottom of the shock to get it to fit in the lower arm.
Don
