Old 06-13-2004, 06:51 PM
DaveR DaveR is offline
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Terry,
I talked to Barry at B&B and he said it is dependent on lining up the water pump pulley and the damper pulley. He said the alternator is easy because you can cut the spacer. I decided that I like the look, and it's cheaper than aluminum, so I bought the chromed steel set from PAWS, with passenger side alternator bracket. If I have to I will use spacers.
This is vbelt of course, and is all for looks, since I already have serpentine style pulleys from salvage, and a flat belt is stronger.
I should have it together in a couple of weeks, I'll let you know how it fits.
