Old 06-13-2004, 08:53 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
You need to remove the sender from the tank and wire it directly to your gauge, so you can lift the float by hand to see if the gauge reads full and lower it to see if it reads empty. if it does nothing, then hook up an ohm meter to the sender to check it's range( if any), it could be a bad sender.
Tim
" It ain't no big deal"
