Old 06-14-2004, 12:30 AM
sagacious sagacious is offline
Send a message via AIM to sagacious Send a message via Yahoo to sagacious
Default too much fuel pressure?
i have pulled the "fuel pump-to-carb" fuel line a number of times after the engine was turned off to pull the top of the carb off and change the secondary jets. when i pull the fuel line there is an excessive amount of pressure in the line that insists on squirting all over the engine until it shortly calms down and stops. im wondering if it is normal to have such a high fuel pressure and what/if it can cause any potential problems with the way the engine runs, and if it might adversly affect the performance of my carburator. edelbrock #1406 (600cfm) 4 barrel. i just have a stock mechanical fuel pump, it could be 30 years old for all i know. could a defective/worn out fuel pump allow too much fuel pressure? vice versa? thanks for the help and time.
