Old 06-14-2004, 09:45 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Trigo FIA wheels are 7 1/2'' wide front and 9 1/2'' wide rear--they have 3 1/2'' offset(D on your image) adapters fit 4 1/2"(ford) 4 3/4''(GM), plus 5 and 5 1/2'' bolt patterns, order accordingly for your particular bolt pattern. The adapters will add aprox. 3/4''--another words your new Trigo wheel will sit 3/4'' further outboard than the current bolt on wheel, usually not a problem unless you have a solid rear axle then you "may" encounter the wheel and tire doesn't fit inside the fender lip quite right.
Hope this helps--Trigo is very easy to work with and if you can give them a call they can and will go out of their way to make sure that you get the correct wheels and adapters. I know it might be difficult calling them from Europe.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
