Don,
The Brake Booster is the Napa 3700142 Mustang II Booster. I will have to check the Master PN but it was one that was discussed awhile back with Right hand side connections. Everything fits perfectly just the Booster Rod seems to be short even using the back hole with the old pedal assembly. I would assume not depressed the pedal should be out farther than it is. Right now it perfectly vertical.
Sorry, I reread my post above and I wrote it backwards. I first tried the front hole as mentioned in the manual (farthest from the firewall) and now have it in the rear hole (closest to the firewall) but am completely vertical with the pedal arm.
