Old 06-16-2004, 06:38 PM
ridelikehell ridelikehell is offline
Cobra Make, Engine: BRM #20, Ford 302, Holley 600dp
Send a message via ICQ to ridelikehell
Default Oil pump broken??? Help!
Yet another problem here...
This started by the fact that I have not been getting any readings from my oil pressure guage...thinking that maybe I might have crushed the line in tightening the compression fittings, I took the line out and found that it's fine...So I fired up the engine without that line in place and I've now realised that the block is not pumping out any oil at all? The engine is a 1989 Ford 302...and I had the hose run to the outlet right beside the oil filter...My question is whether or not there is a way to confirm that the oil pump is actually pumping, or is it just for some strange reason not pumping out that hole???
Any help would be greatly apreciated!
--Dave.
