Old 06-16-2004, 10:35 PM
rr454 rr454 is offline
Cobra Make, Engine: Johnex3 w/460 crate & 5 gear
Dave,, I am not real familiar with SBF, but if you have an old distributor laying around dismantle it down far enough to turn the oilpump drive shaft with a drill. You will have to cut the advance mechanism off the shaft and grind off the drive gear teeth to make it work. Then spin the shaft with a drill and you should "feel" the resistance if it is pumping,as well as the gauge psi increasing. If it does not, add 2-3 liters of oil to bring the level up over the pump body .and if the pressure increases then you do indeed have a broke pickup tube, but do run the engine at this oil level as it could hydraulic lock.
Hope this helps.
Dave
71 LS5 Vette roadster, 71 Z28, 70 L78 Nova SS, 89 GT 5.0 Rag
