Old 06-18-2004, 07:51 PM
Rick Parker's Avatar
Brent: Connect the heavy Red wire to the positive side of the starter solenoid, the black wire to a solid ground on the engine or chassis. The small red wire normally goes to to pole on the ignition switch that becomes hot when the key is in the start & run position (use a volt meter). It must be hot in both positions but no voltage when key in off position.
Rick
Rick
