Old 06-19-2004, 06:43 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Jeff,
My Lone Star has the same shocks and spring rates as Tim's does.Has 10" springs.
Your lower rear shock mounts have two mounting locations.Going to the lower hole makes about 3/4-1" difference.
What length are your springs ?
You don't want to lower it to the point you bottom the shocks out on bumps/dips.
The shocks don't have a lot of travel,work at getting the ride height in the middle of the stroke.
Of course changing your ride height means a frontend alignment and checking your pinion angle.
