Old 06-20-2004, 11:56 AM
casaleenie casaleenie is offline
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Took the liberty of taking this from the Unique Forum posted by Eliminator... Might be something that is applicable for other brands as well... With tire rounding and this Vibration Resistor, wheel shake and shimmy might be a thing of the past....
Posted - 11/20/2003 : 05:40:09
Just worked out a deal this week with Flaming River who makes the Unique steering u-joints for a Vibration Resistor. The reason all of us have a vibration problem is that there is no dampner between the Manual Rack and Pinion Steering and the steering wheel. Flaming River use to make a dampner that went in the center of the steering shaft, you had to cut the shaft take out a section then insert the dampner, did the job but a pain in the $ss. At the Steet Rod Nationals I approached them about this. They showed me a new concept, making the Vibration Resistor in with the U-Joint but they didn't have one to fit the Unique spline which is a 3/4"-48, both end's. Now we will have one, we have 6 on order that we should get in 4-6 weeks to try out. This will replace the u-joint that comes directly off the steering shaft (you need it as close to the steering wheel as possible), looks similar but is a little longer, approximately 1", will be nickle plated steel like the present joint, has thermoplastic rubber to absorb vibration and "road feel" from the steering system. Actual does a great job as there are some Unique Cars around with the old system. The short shaft that comes out of this joint will have to be replaced, needs to be shorter, and thats it. So it is pretty easy to do, about a 1 hr job. Price, Unique will have to give us a quote, but around 200.00 or less, need just the 2 parts, a Vibration Resistor U-Joint and a new shorter 3/4"-48 splined intermediate shaft. Keep everyone updated. WWW.flamingriver.com
Eliminator
