Old 06-21-2004, 03:42 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hello:
I suggest that you mount the MSD inside the cockpit, behind the passenger side dash. It is much cooler there. What kind of distributor are you running? Is it a Mallory as well?
I run the Mallory distributor in my FE with the MSD 6/AL. The thing is rock solid. I had to be careful to route the signal wires all by themselves from the 6AL to the distributor and coil so that I would not get Tach cross talk (bobbling tack or wandering).
I also used a ballast resistor and the Mallory Active Power Filter to protect the ignition "eye" inside the distributor.
Good Luck and I am sorry to hear about your heat problem. It goes with the territory I guess.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
