Old 06-22-2004, 06:59 AM
jjtarnow jjtarnow is offline
Cobra Make, Engine: Everett-Morrison 514ci, 5sp Tremec
Guys,
Well, I had the leak down and compression test done..thankfully, every cylinder read almost idendical to one another (whew!). The car is running fairly rich and I am going to do some spring and rod work to the Edlebrock's this weekend. My cam has so much lift that it's generating very little vacuum at idle so I need to make some adjustments. I am still getting a tad too much smoke out of the right bank (which based on the plug read is running richer than the left bank) I still may have valve seal leak but either way I need to deal with the richness issue first. Any thoughts would be greatly appreciated.
Josh
jjtarnow
