Old 06-23-2004, 06:40 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Sal:
Either the Accusump or an oil pump made for the specific purpose of pre-lubing the engine should do the trick. Information on the Accusump is fairly easy to find while the actual pumps take a little more digging. Try http://www.espperformance.com for a pump type system (pick the pre-luber option). From my research this looks like one of the better units. Their turbocharger system even allows the pump to keep circualting oil for a period of time after the engine is shut down to prevent coking of the oil on hot parts.
The idea of the pre-lubing rather than just turning the enigine over without ignition is to get oil on the parts "before" they start to rub against eachother. I know that turning the engine over with just the started doesn't turn it that fast but it's still turning it and bare metal contact doesn't take all that much to wear. Both the Accusump and the pre-lube pumps eliminate this and, relatively speaking, they are not that expensive and simple in their operation which translates to minimum problems after they're installed.
Just my $0.02.
DonC
