Old 06-23-2004, 10:20 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
If it was me I would put the original clutch fork and throw out bearing back in the car. Hydraulic T/O brgs are sometimes a pain.
But that is not what you asked. Yes, you can do it if you are comfortable pulling the transmission, if it is an internal T/O Brg. Instructions will walk you through the install. Be sure you bench bleed your hyd T/O brg before you install it. If it is an external one it is even easier. Be sure to bleed the T/O bearing good enough to get all the air out.
Clois
"Let's roll"
"Be part of Something Good
