Old 06-24-2004, 04:01 PM
Mike H Mike you will have the same problem again, the pin will fgix the hole but not be tight. That pin is there to stop the cam sprocket from going back and forward. That pin should never wear out. The fuel eccentric uses that pin to run and move the fuel pump arm. Those techs at crane and comp don't know crap at times. 1 note a went with the FFP gear and chain and had no problem other than the pin size. If a good drill bit at the .003 size and loctite it in. Press it don't hammer it in. Rick Lake
