Thread: Over heating
Old 06-28-2004, 07:04 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
May I suggest a small test?
Take the T'Stat and put it in a pan of boiling water. If it opens, Completely, it may not be the T'Stat.
The hole should be no bigger than 1/8" as stated by BIB, The rating is a matter of choice, however, you might want to select a 180 to 190 degree unit. Installed with the point towards the radiator.
If you have a tank on top of the engine, I think you can see if the coolant is flowing once temperature has been reached.
I Like the idea of the IR thermometer. Thermo-imaging would a whole bunch better.
Did this just start or are you just getting the engine up and running. More history would help. If this is a first time run, you may have other problems that go beyond the T'Stat.
Just my $0.02
