Old 07-01-2004, 08:33 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You have to check input shaft distances and compare them to the stack height of the clutch, PP, and pilot bearing. Just takes a piece of dowel or welding rod, a magic marker, and a straight edge.
The input shaft could be puting a heavy thrust load on the crank at either the pilot bearing or by shoving the disk into the flywheel due to a too-deep installation.
