Old 07-04-2004, 05:38 PM
Desertson Desertson is offline
I can't immagine a 351w with the water pump even with the deck, It seems to me as though this would require a whole diffrent water pump/timing chain cover assembly. On a 351 the water passeges for the pump on the block are a little more than an inch lower than the deck. On evrey windsor I've seen 351 was clearley cast in the lifter valley. 351 should also be cast into the heads if they are original, the number would be alone with no letters between two valve of the springs, of course on my other 351 has "302" is cast into the heads, so the heads will be of little help. I admit I have no idea what the 5.8 casting numbers look like. It hurts to say it, but chevy casting numbers make much more sense than ford's.
