Old 07-05-2004, 06:03 PM
DAVID GAGNARD's Avatar
Dan;
For a motor that you want to get somewhere between 350/400 hp,I do not think the extra expense of a hydraulic roller cam is worth it with so many hydraulic flat tappet cams on the market.....Take the extra money you would have spent on the roller set-up and put into some good cylinder heads/manifold/carb...... Then get a set of poly-locks for your rocker arms and set them as per the cam manufacter's instructions,they should never need re-adjusting....Just set it and forget it.............
Solid cams roller or flat tappet need adjusting and are for mainly higher hp engines..........
David
DAVID GAGNARD
