Thread: oil in water
Old 07-11-2004, 04:55 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Did you go back over the heads after you ran the engine? Edelbrock ask that you check the head bolts after running the engine as the heads will grow and the bolts will in some cases become loose. That can cause poor running and oil in the water. Does the dip stick show that the engine is low on oil after you run the car?
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
