Thread: Engine mounts
Old 07-11-2004, 09:42 PM
pneall's Avatar
pneall pneall is offline
Ian is running a new pedal set with some offset to left to allow use of rose joint for clutch adjustment. I added extra offset to clutch and brake pedal to give more room around accelerator. Check out Mikes gallery for pic. If you just buy blanks from Ian its easier to bend. Accelerator pedal is from AU falcon but needs work.
Ian makes FRP and Carbon Fibre dash. I went with FRP and covered but would probably just cut up some aluminium sheet if I did it again.
I think you only need front sway bar but wouldnt recommend Ians as I dont like using Jaguar mounting points.
SAAS in Melb make a nice seat.
Get all your bright stuff gas cap, bumpers windscreen and especially side air vents from Don Pilling at Snakebite in QLD. The quality is fantastic.
Phil
