Old 07-14-2004, 12:26 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
One option is to wire a kill switch in the low amperage relay circuit. Thus when you shut down the motor you have the option to allow the fans to run until the coolant temp drops or flip the switch to kill the fans immediately. Another option is to wire the low amperage current thru the relay from the ignition switch. That way when you shut off the ignition, the fans will shut off also.
Rupert Hartmann
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
