Old 07-15-2004, 09:55 AM
XXQQQME's Avatar
XXQQQME XXQQQME is offline
Cobra Make, Engine: West Coast, Ford 460
Thanks for the info on McLeod, however I just ordered my new Tilton Engineering t/o bearing and base today. I think I'll keep my McLeod and return another day.
I think I will do the same set-up regarding the pedal stop. . . bolt and nuts. Did you tack weld anything? I would like some input as to the trick of establishing the pedal stop distance . . . trial an error? Put it in gear while car is on an incline and push clutch pedal down until the car rolls? Also, did you attempt to duplicate the angle of the pedal arm in any way i.e.: angle block, rubber etc??
Thanks again for da input,
Kim
'bacher
