Old 07-18-2004, 08:01 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Bruce,
Have you tried FelPro for the gaskets? Also are you sure about the oil pressure? Check it with another gauge to be sure.
If you call me tomorrow I can pull up the OEM specs for a cam and you can go from that point. If you do not mind adjusting the valve train every now and then stick with the solid cam. It willl rev higher.
407-857-8587 Mon-Fri 9:00-5:00 EST
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
